5 members (Brian Moore, texas46, dt235sd, TexasA&M48Truck, Steelonsteel), 59 guests, and 1 robot.
Topics128,022
Posts1,055,381
Members48,422
#838507 03/25/2012 5:23 PM
Fellow Stovebolters,
I am currently working on reinstalling the front axle on my 54 3100. I am wondering if there are any tricks to set the caster shims when bolting up the axle to set the camber. I can't seem to find any breakdowns or diagrams online. Thanks for any tips.
Maybe someone will post a practical way to measure the degrees of caster angle and where to find shims.
I just put the original shims back in and hope that is OK.
tclederman #838526 03/25/2012 6:33 PM
When you put them back, did you have the thick end facing to the front or to the rear and did you have the side with the two notches facing up or down? Thanks
Riding in the Passing Lane
The thick part goes to the rear. I'm not familiar with any nothes. It shouldn't make any difference.
1972 Chevy c10 Cheyenne Super
As Wrenchbender posted, the thick part is to the rear.
Here are some photos of an original shim. There is a hole in the middle to clear the spring-pack center-bolt head. There is a "locating pin" on one side and a slight dimple/indentation on the other side of the "pin". I found a few shims in my parts box that had the pin sheared off and almost no indentation on the backside of the pin.
tclederman #839118 03/27/2012 6:33 PM
Thank you very much
