0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 4 New Guy | | New Guy Joined: Mar 2012 Posts: 4 | I'm having a hard time locating rear axle seals for my 1950 3600. Chevs of the 40s lists but unavailable until further notice. Other sites list a seal that works from 1946-1972, but not sure I trust that. Anyone know where I can pick up a pair? | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Local parts store is your best bet. Got my last pair at Autozone or NAPA.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | The 46-72 is correct. GM used the HO72 up until 1972, then they went to the 14 bolt. The 8 lug HO52 and 8 lug HO72 were basically the same, just different ring/pinion center section combinations. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Go get them in Denver here. I bought mine from their store here locally in Rapid City yesterday for my 1 ton.
Bruce | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 |
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Mar 2012 Posts: 4 New Guy | | New Guy Joined: Mar 2012 Posts: 4 | You guys are great. Thanks for all the tips. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | When looking for seals or bearings.If you look at the seal there should be a # stamped on the face of the seal if you take that to a FLAPS they should be able to match one up for you.Same with bearings.
Pete | | |
