6 members (wilbur53, Steelonsteel, UtahYork, Rich'sToys, Bill Hanlon, Ponchogl), 83 guests, and 0 robots.
Topics128,113
Posts1,056,616
Members48,450
I have a '48 big bolt and I'm sorting out the wiring. If I have continuity from high to low beam and from low or high to ground would that mean a bad light switch? (Everything else being ok)
I found the same continuity between all three terminals on the bulb - not installed in the truck. I was checking the 12v headlight bults in my '54 last week for condition and to determine which terminal is High / Low / Ground. Haven't reinstalled them yet. Kinda confusing - don't know why.
- Lonnie
My '54 3104
Check the hi/low beam foot switch (on the toe board near the parking brake). That is where the two wires meet. The switch could be bad.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
3B Offline
Hy Guys, the headlights have two different powered terminals, but they have only one common ground terminal, that is why there is continuity between all three terminals on the headlight, hope that helps.
Thanks guys for all your input, but should there be continuity at the inner fender terminal block (high beam, low beam, park)and ground? If I have one probe on ground and touch the other to each wire at the terminal block I get continuity.
Ben - if you're checking that continuity with the bulb in place, you're measuring thru the bulb, if you had no continuity that'd mean that element was burned out
3B -
Thanks for explaining why the bulb has continuity across all terminals. I shoulda figured that out myself. Guess I'm loosing more grey cells than I thought!
- Lonnie
My '54 3104
Thanks red58
I thought I was going to have to replace the light switch.
Ben
