| | | Forums66 Topics128,196 Posts1,057,385 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | On a 51 3600 What color should the underside of the fenders be?
And then on the running boards are they black or body color?
It's time to start putting some paint on the sheet metal and I want to leave the option of being totally stock open. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Originly from the factory the underside of the fenders would have been black e-coat primer with a little overspray from the body finish in spots. http://www.pbase.com/dennygraham/image/142243140/large The running boards would have been gloss black. DG
Denny G Sandwich, IL
| | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | Perfect The black epoxy that is the base primer coat is just like the factory might even hold up fairly well | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's correct, I'm using PPG DP90 primer on all my bare sheet metal. DP90, unlike primer surfacer it isn't porous so it won't soak up water and it looks as close to the original primer GM used as you’re gonna get in my opinion. Denny G
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I am also using the PPG DP90LF black epoxy primer as a good match to the original black primer.
