| | | Forums66 Topics128,010 Posts1,055,305 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 16 New Guy | | New Guy Joined: Apr 2011 Posts: 16 | I AM PUTTING THE ENGINE BACK IN MY 53 CHEVY P.U. I CANT REMEMBER HOW THE FRONT MOTOR MOUNT IS ASSEMBLED. IT SEEMS SIMPLE ENOUGH, BUT I HAVE A 52 I'M LOOKING AT AND IT HAS TWO WASHERS BETWEEN THE MOUNT AND FRAME, I DONT RECALL THAT ON THE 53 ,BUT THEN AGAIN I TOOK IT APART TEN YEARS AGO.AND THE TWO MOUNTING BOLTS GO UP FROM THE BOTTOM SO THE NUTS ARE ON THE TOP AND BOLT HEADS ARE ON THE BOTTOM .IS THIS THE CORRECT WAY TO REASSEMBLE OR DID THINGS CHANGE BETWEEN 52 AND53 ALSO IS THE SEAT FRAME PAINTED THE SAME AS THE STEARING COLUMN COLOR? THANK YOU BABE | | |
