Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (baldeagle, Ponchogl, TooMany2count, Robert Crandall), 48 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#837487 03/22/2012 2:18 AM
have a pontiac 350..install new 6oo holley carb. and headers..when i burn out starts to pop from carb...when i accelerate and let up it pops through exhaust...isn't the carb set a factory...need help
696969 #837499 03/22/2012 2:33 AM
3B Offline
Hy 696969, if your Holley has the sight plugs for setting the float level, check the float level. If the carb has been backfired through, it probably has destroyed the power valve inside the carb. Carbs are set to a basic setting, they need to be tuned and setup for specific applications. It sounds like it might be leaning out on acceleration, hope that helps.
3B #837515 03/22/2012 2:53 AM
so what should i do about it ...know little about the carb
696969 #837567 03/22/2012 5:13 AM
3B Offline
Hy 696969, If you can't work on it yourself, then look for a tune-up shop or a high performance shop that works on carburetors to check/rebuild your carb and do the setup on the engine, hope that helps.
3B #837603 03/22/2012 10:10 AM
i will do that3B,thanks for info...
