1 members (2-Ton),
133
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 34 New Guy | | New Guy Joined: Mar 2011 Posts: 34 | I have a 1948 216 in a 1951 pickup. On the starter right behind the starter solenoid there is a switch. From what I see in catalogs (Obsolete Chevy Parts Co.),it is called a Starter Motor Reversing Switch? I am finding they where used until 1948. What is the purpose of this switch? Why didn't they come on engines after 48?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Most likely you are referring to the ignition reversing switch? " The switch is mechanically actuated when the starter is actuated to reverse the polarity of the ignition system on these vehicles. " Not that I know what this does. Someone posted a good explanation this year. Maybe they will post it again here. http://chevy.oldcarmanualproject.com/shop/1947truck/47ctsm1228.htm | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | If I remember correctly, on the 41-47 series engines, the distributor was not naturally grounded. The reversing switch controlled which way the current flowed through the points, so that (theoretically) there was an "even" amount of wear on each side of the points when they closed. (as is, because the current flow is all one direction, one side of the points wears out faster than the other side - I'm sure there's some fancy name for this phenomenon - "electro-carbon-fracturaization" or something! ;-) With the reversing switch, each time the truck was started, the switch was flipped mechanically, so that the direction of electron flow flipped directions, thereby causing even point wear, and longer-lasting points. Theoretically.
Eventually, someone at GM came to their senses, and realized that this over-thought solution was more expensive than the problem it "cured" in the first place. GM published a bulletin explaining how to take the switch out of line, and add a grounding jumper to the distributor.
Or so I assert, anyway . . .
-Michael | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Michael,
Good explanation, I think.
I have a copy of that Service Bulletin (I read it about 2 weeks ago). I'll see if I can find it.
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | The polarity reversing switch was supposed to equalize metal transfer between the points by switching the direction of current flow at every operation of the starter. Eventually, somebody figured out that metal transfer was caused by the capacitance of the condenser being incorrect. The polarity reversing switch was an over-complicated mechanical solution to a relatively simple electronic problem. Jerry
