1 members (Russ_B_10),
91
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 94 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 94 | I have a very good body to a 1941 chevy 1/2 ton with no frame and i just found a good frame for a 1953 chevy 1/2 ton. I was wandering how much work and modifications would be needed to put the 41 chev body on the 53 Chev frame. Any help or advice on this swap would be greatly appreiciated. Thanks in advance  | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jordi55, that shouldn't be too hard a swap, the two frames are similar in design, good luck with your swap.
