0 members (), 126 guests, and 3 robots.
Topics128,101
Posts1,056,181
Members48,436
#837338 03/21/2012 7:06 PM
I have a saddle tank out of a 48 Chevy that I an installing on my COE. Does the line pickup line in the tank have a check valve in it. I'm trying to clean the line and can't blow nor get a piece of wire through it. The tank had some junk in it but was in fairly good shape. I also put 100 LB psi through it, no luck. I'm attempting to work the line from the outside in (reverse of the way the gas would go).
Jason
1946 GMC COE
1967 Pontiac Lemans Convertible
http://s1275.photobucket.com/user/jrpontiac/library/?sort=3&page=1
3B Offline
Hy Jrpontiac, all the tanks I've been involved with have had nothing but an open connection in them, hope that helps.
Lots of pick up tubes had a screen soldered to them to keep from sucking trash. If the gas in the tank evaporated the screen could be blocked with shellac. If it were mine I'd pull it out, clean and inspect it.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I cut a hole in the top of the tank, no check valve. Pickup top was just clogged, cleaned it out with choke cable housing attached to my drill. Welded up hole and am good to go.
Jason
1946 GMC COE
