| | | Forums66 Topics128,014 Posts1,055,325 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83736 10/04/2007 9:26 PM | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | Hi, I would like to put a 305ci v8 in my 1946 chevy pickup. Where can I find info or who can help me with some information. Thanks, Jan [email protected] | | |
#83737 10/04/2007 11:00 PM | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Unbolt the 6, bolt in the 8. You will need a new flywheel housing for the v8 as the starter is in a different location.
Other than that, search the archives and the internet. Much information out there if you have never done it. However the Chev 6 to Chev 8 is about the simplest swap you can do.
Scott
#83738 10/05/2007 1:12 AM | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Change to 12 volt, use either side mount or front mount.Move steering box, 1 3/4-2".get hugger headers,or find exhaust manifolds that clear the frame and steering box.Good for a few weekends of work.Might as well go to HEI distributer. Lothar | | |
#83739 10/05/2007 7:23 AM | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | Thanks, move the steering in wich direction ?
I looked on the internet, unable to find anything, can somebody post a link. | | |
#83740 10/06/2007 9:00 AM | Joined: Nov 2004 Posts: 35 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 35 | Piper,  you have to space the steering box away from the frame. In other words moving it towards the drivers side tire. This gives you more room for the engine. Had to do the same thing to my 50. | | |
