Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Barnfind49, Stovebolt48), 120 guests, and 4 robots.
Topics128,277
Posts1,058,456
Members48,490
#836816 03/20/2012 4:40 AM
Hey guys. I am deciding on how to do the suspension on the front of my 52 3600. It will be supporting a small block v8. The plan for my truck is an old original look but with modern conveniences. Im not going to lower the truck or anything like that. Although I do want to run an air ride system for different reasons. I want to be able to adjust the stiffness of the ride according to what is being done with the truck. I want to remain around stock ride height or a little higher. I going back with the skinny knobby looking tires farmers would have use back then but radials. Have any of you guys built one off front suspension on the original frame? bc Im really not looking to go into a frame swap. Im wanting to be a little different. Or what have you guys done similar?
thanks
I kept leaf springs and added some air helper springs.
http://rides.webshots.com/photo/2442517350080251109qamrVM
The weight of my engine/transmission and cab flattens out the leaf springs and then the air helpers bring it back up to ride height.
Here it is with no air
http://rides.webshots.com/photo/2324065910080251109mrqkVs
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
mo Offline
how about a 3 link set up with custom brackets for the original axle with some air bag springs in place of shocks. guys do it on solid axle 4x4s all the time. i dont know why it wouldn't work with the original axle.
MO's 1951 chevy 3100 resto mod project
the air bags on the leaf springs would def be an easy way to get the ride height. I like the 3 link idea I may do some more research on that. thanks guys.
Grigg how do you like the air assist bags as adjusting ride firmness?
I've driven my truck a few miles down the road and back and it rides good. However I don't have any real use on it yet so time will tell if its a great system. And I still need to put shocks on it.
I don't have any worries about it though.
Grigg
---All pictures---
