1 members (dt235sd), 307 guests, and 7 robots.
Topics128,159
Posts1,057,039
Members48,460
#834326 03/11/2012 10:52 PM
Need to change the petcock under the fuel tank on my 49 half ton and before I pull the old out I'd like to have a replacement on hand. Does anyone know the size or have a part number? I am talking about the valve where the fuel exits the tank and connects to the short flex line.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Crusing in the Passing Lane
That item is probably a hardware store item, probably .25" pipe, good idea to bring a new one to keep the bath time to a minimum.
I'd like to find out exactly before I even attempt to change the original.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
If you have a NAPA store or anyone who carries Weatherhead brass fittings, they should be able to help. Edelman brass probably still makes one too. Good luck!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
V
V Offline
Good idea to bring a new one to keep the bath time to a minimum.
