0 members (),
125
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83642 09/29/2007 3:20 PM | Joined: Apr 2007 Posts: 26 New Guy | | New Guy Joined: Apr 2007 Posts: 26 | Hey guys, The 50's v8 motor mount are they the same for car and truck? I have a 55 1/2 that I need motor mounts for. I plan on putting the stock 265 back in her. I've found the v8 car motor mounts for $50 complete set. Just wondering if they are the same length or not. Thanks K. Bellyjello | | |
#83643 09/29/2007 5:09 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't know for sure if they're the same or not, but the correct truck mounts are redily available from virtually any of the parts houses. Try American Classic, link at the top of the page
Bill Burmeister | | |
#83644 09/29/2007 5:57 PM | Joined: Feb 2004 Posts: 29,818 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,818 | The trucks I remember working on back then had a horseshoe-shaped front mounting bracket that bolted to four holes beside the crankshaft damper, with one set of rubber supports at the center. 55 through 57 passenger cars had two small brackets, with a mount on each side. The cars went to side mounts in 58, not sure when the trucks made the switch. Jerry
#83645 09/29/2007 6:11 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
#83646 09/29/2007 10:13 PM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Hotrod and Longbox are both correct. The bigger trucks did use the "U" mount and the smaller was like the cars. A third type (Corvette) mounted between the waterpump and block and sit on biscuit mounts on each side.
Evan
#83647 09/30/2007 12:50 PM | Joined: Apr 2007 Posts: 26 New Guy | | New Guy Joined: Apr 2007 Posts: 26 | I can't seem to find the bolts on american classic truck | | |
#83648 09/30/2007 2:47 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not "bolts" but complete mount kit - find'em here as ME830 - you won't find the individual pieces any other way Bill | | |
#83649 09/30/2007 3:10 PM | Joined: Apr 2007 Posts: 26 New Guy | | New Guy Joined: Apr 2007 Posts: 26 | Hey Bill, I need the bolts too, Mine are all twisted and bent. Thanks for the reply | | |
