0 members (),
116
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 6 New Guy | | New Guy Joined: Mar 2009 Posts: 6 | Im having trouble with my 64 c-10. It has a 250 6 cylinder engine.
When put under a load the engine stalls. To get home I have to fully choke the carb and feather the gas. I replace the fuel pump today and that helped for a while. I drove about 3 miles with no problems then all of a sudden it started doing the same thing.
Any ideas?
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | did you check your fuel filters? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Also, check the filter sock on the sending unit in the fuel tank. When the fuel is agitated, sediment will clog the sock and drop off when the engine stalls, when the suction drops from the pickup tube. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Loosen the gas cap. Takeing a few miles before it shows up brings up the possibility of a cloged up vent or improper gas cap. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2009 Posts: 6 New Guy | | New Guy Joined: Mar 2009 Posts: 6 | I did replace the inline filter and that didn't help. I will try the gas cap thing and see what happens. I went ahead and ordered a new sending unit and carb today though. Hopefully that helps. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Ive had similar probs before, carb was cloged up with krap from the tank and other time vacuum adv line was off producing huge vacuum leak. good luck | | | | | Joined: Mar 2009 Posts: 6 New Guy | | New Guy Joined: Mar 2009 Posts: 6 | I did replace the inline filter and that didn't help. I will try the gas cap thing and see what happens. I went ahead and ordered a new sending unit and carb today though. Hopefully that helps. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | When you take the sending unit out of tank you may want to see if the tank has a bunch of mud, varnish in it. | | |
