3 members (1955 1 Series, Otto Skorzeny, Gdads51), 51 guests, and 1 robot.
Topics128,037
Posts1,055,580
#835952 03/17/2012 3:08 AM
Having trouble turning over my 54 gmc. I have to pump the gas a couple times and then floor it just so that it remains running. After a few seconds i can let go of gas but it will continue to run rough a bit.
- At idle oil pressure is 15 running it is between 30-45
- The tstat is consistent at 140 and no over heating issues.
- There is a single barrel zenith carb on it that I sprayed with Gumout carb cleaner but showed no improvement.
- Fuel tank has been boiled and cleaned.
- Fuel lines look good and fuel filter shows clean and clear with no sediment visible.
- I haven't fooled around with carb other than Gumout.
- All wires are good as well.
The numbers I got off engine were:
152 24P Z2686
2194819
any ideas??
54GCPGMC #835963 03/17/2012 3:55 AM
That oil pressure is low for a GMC but that wouldn't affect the running.
Sounds like a carb rebuild is in order.
If you have an adjustable main jet you could remove it and check for trash in the opening. Before you take it apart screw it all the way in and count the number of turns so you'll know where to set it going back.
Cletis #835983 03/17/2012 4:46 AM
Have you checked the point gap?
My Blog
Pre '68 Dave #836019 03/17/2012 11:45 AM
havent checked the point gap. Will look into the carb as well
