| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 46 | 49 cab on a S10 frame. If I use 2 inch dropped spindles, how high off of the frame should I put the cab so as not to hit the fenders with the motor in it?. Or if keeping the orginal spindles, the same question applies. Please help me. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy fubar49, I don't really understand your question, are you concerned about the fenders hitting the ground? There are kits out there for mounting the old truck bodies on the "S" series chassis. Lowering the stance of the truck by using dropped spindles does not change the position of the cab relative to the chassis. If you could explain what your concern is a little better, maybe we could answer your question a little better. | | | | | Joined: Mar 2012 Posts: 174 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 174 | Got a buddie putting a 59 Apache on a s-10 frame. 225-60-15 fronts n 275-60-15 rears. AS IS- IN THE WEEDS! A HAIR FROM SPARKS! Stock s-10n set up. Hope this info helps. Stranger | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | It might be worth it to just sit the cab on the frame and measure from there.
Drew
