6 members (Donf, Gray_Ghost, Peggy M, SWEET, mvigo, rfs56trk), 48 guests, and 3 robots.
Topics128,023
Posts1,055,367
Members48,420
#835836 03/16/2012 7:46 PM
want to put bed roll lights back of box of pick up...one of the tubeler piecesi dented up...how to straighten out...
696969 #835837 03/16/2012 7:50 PM
find a piece of heavy wall pipe that's a snug fit, bevel the end slightly, tap it in carefully, if there's enough depth to get in a bit and no real kinked creases it might work
696969 #835838 03/16/2012 7:56 PM
before or after paint and body?
Before: find a piece of steel pipe that fits inside, (I had a cannonball that worked perfect), and get your hammer to work. A little MAP gas torch heat will make the job go faster. If you have any cracks weld them up and shape it while it is still hot from the weld.
After: I will leave to the Paint and body experts.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
