| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 118 | want to put bed roll lights back of box of pick up...one of the tubeler piecesi dented up...how to straighten out... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | find a piece of heavy wall pipe that's a snug fit, bevel the end slightly, tap it in carefully, if there's enough depth to get in a bit and no real kinked creases it might work
Bill | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | before or after paint and body?
Before: find a piece of steel pipe that fits inside, (I had a cannonball that worked perfect), and get your hammer to work. A little MAP gas torch heat will make the job go faster. If you have any cracks weld them up and shape it while it is still hot from the weld.
After: I will leave to the Paint and body experts. | | |
