2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
#835383 03/15/2012 3:37 AM
Does anyone know the names of the engine paint colors for:
1957 Chevy 6500 with the 6 cyl.
1957 Chevy LCF with the 8 cyl.
?? Thanks
hotshoe99,
The 1957 6500 came stock with the Jobmaster 261 6-cylinder which was Yellow.
The 1957 5000 & 7000 Series LCF's came with the Taskmaster 283 V8 which could have been Orange, Green, Black, Yellow or Gray.
The 1957 9000 Series LCF's had the Loadmaster 322 V8 which was Red (not Cherry Red it's more of a Red/Orange).
Hope this helps,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike B. Yes the info is surprising to me. Never knew they were yellow.On the Chevy 5700 series with all of those different color possibilities, was it a choice or...what would determine the color for that particular truck ? Would you happen to know who makes the correct yellow ? Is it a CAT type of yellow ? I have a good connection for PPG products.
Let me do some checking...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Yes, the 1957 261 was supposedly yellow.
Here is a yellow 1955-1st 261.
Here is another photo of that same yellow 1955-1st 261.
Those photos were provided by the late WD Foster. WD stated that he was certain that it was original paint - I'd believe such an assurance from very few people, Warren was one such person.
Looks like a Minneapolis Moline.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Looks to be a '54 - 55 1st design 261 by the water pump mounting & s/n location.
BC
1960 C60 pasture art
BC59 #835603 03/15/2012 10:11 PM
BC, Thanks for the correction (I've changed the post).
Tim,
Thanks for posting the pictures that's the color I remember.
I think MM and Cub Cadet are both a little to orange. I think it looks closer to a faded John Deere yellow.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Looks to me to be about the same color as a Cat engine (ORIGIONAL PAINT) from that time period. My'55 2nd-series 261 still has plenty of evidence of its origional"Cat-Yellow" (Close enough 4 me),even though it's got 3-4 layers of Chevy orange over the last 57-years. I was born in'57,and now I'm 55,and my truck was "born" in '55,and "he" will turn 57:)
Mo' Tater
Originally Posted by Mike B
hotshoe99,
Hope this helps,
Mike B smile
I'm shocked how many different engine colors were available
Having the engines different colors allowed the assembly line to quickly know they had the correct engine in the truck.
I have heard when the 283 came out in 1957 they painted them different colors based on what options it had.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
That makes alot of sense
I found that the intake manifold on my '54 235 is yellow when I stripped off the top layer of paint to prep for new engine paint. Wonder if it came from a yellow 261? Casting code #3835590 was used on 235's and 261's.
- Lonnie
My '54 3104
Lonnie,
That makes sense to me. The engines were assembled and then painted, so if you found yellow it would indicate it was indeed put on a 261 before it was put on your motor (assuming a PO didn't paint your motor yellow just for the fun of it).
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B -
Another piece of the puzzle (possibly) solved! My '54 has a 1959 head, so the intake manifold may have been substituted at that time. Most of the numbers on the truck are period appropriate. The manifold casting number was used on 1954 and later 235's and 261's.
If it is the original paint, then here are a few earlier pics for anyone trying to match the color. The pics were taken a year or so ago. The acetone I used to clean it for painting took away a little of the brightness, but it was never Cat yellow or state highway department yellow.
< Old Pic 1 > I bumped up the contrast on this pic, so the color may be a little more intense than in "real life."
< Old Pic 2 >
< New Pic after scrubbing with acetone >
- Lonnie
My '54 3104
What color would a GMC 270 or 302 be?
Cornerwindows,
I can't help with GMC stuff, I have lots of literature on Chevy, nothing on GMC.
Spanky should be able to answer this...maybe you should start a new thread titled "GMC Engine Colors" so it will be easy to find at a later date.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
