4 members (Swami29, Otto Skorzeny, Gray_Ghost, Youngin' Tut 59), 143 guests, and 1 robot.
Topics128,114
Posts1,056,605
Members48,448
You know how in this hobby you seem to always get the order of build out of whack?
One mal-whack is to paint the interior and then think about seat-belts. I have been looking and thinking about the Juliano 3-point belts for 4 or 5 years now. So last month I bought a set. I keep reading the directions and wondering if I really need to spot weld the two holes on the door post.
Juliano's
That would necessitate repainting the post and whatever else I gummed up. I assume the two 1/4 holes need securing to keep the plate from spinning. However I wonder if I could tap the holes and use a screw to hole the plate steady. I don't have the truck here right now but I wonder if there is enough room behind the post to fit a nut back there as well.
Any suggestions will be appreciated.
~Jim
There are special blind nuts that should work. Check with any good hardware store.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
What are "blind" nuts.
~Jim
It just so happens that the current issue of "Classic Trucks",May 2012, has a pic article for installing Juliano's 3 point belt system in a Tri-Five truck. Perhaps info there will help you.
Drew
I don't see why the nut needs to be welded. Once it's tight it aint going anywhere.
On my '56 I welded a bar to the nut and poked it up in the hole. You might be able to do that on the AD to hold it while you tighten the bolt.
'56 belt install
I put Juliano's 3 points in my 51 panel.
I'm not acquainted with the set up on a pickup, but, I did weld in the plate.
I'm covering that area around the plate with upholstery (headliner) material anyway, so, I'm happy with the installation.
Juliano's stuff is great and I've but in several sets of harnesses and belts over the years
I suggest you take a look at Seatbelt Planet https://www.seatbeltplanet.com/seat-belt-101/ It looks like they make Juliano's product and sell for about 20 less per side! You can't go wrong with their directions either!
Les
To late for me. Just finished installing Julianno's on Sunday.
~Jim
Moderated by  ndkid275, Phak1
