0 members (),
128
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,077 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 37 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 37 | I've been thinking how cool a serpentine belt would look on my 235. Hoping that some of you have did this so I'm not wasting time and money trying to figure what will work and what will not. Or is there a vendor that makes a kit? I'm using a alternator without air. | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | Moost serp belts run on a reverse rotation water pump, also the belt load is much higher than v- belt, might be more than the pump bearings can handle.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2000 Posts: 5,224 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,224 | A serpentine belt needs more then one item to run around, like a/c, p/s, alt, water pump, etc....
I think maybe you are just looking at a ribbed, 4 or 6 grooved, flat back belt. If thats the case, hunt down a late model small block Chevy and see if you could rob the pulleys. You might have to adapt and modify, but it could be done. This type of belt shouldn't load the water pump any more then a V-belt does.
Joe | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I genuinely doubt that you can put a serp pulley on the water pump of a 75 y/o engine. Simply not made for it and seems very difficult to modify. | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | [quote=Joe H I think maybe you are just looking at a ribbed, 4 or 6 grooved, flat back belt.
Joe [/quote]
Even less load for The same grip, got me thinking now!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | What's wrong with the stock setup? | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I'm going to have to detract my original post and side with Grigg. A stock 235 only needs a belt to run the water pump and generator. No real need for a serpentine. Unless you ad air and power steering, maybe modifying for a serpentine setup would be kind of cool. Lots and lots of fab work though. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Maybe you guy's have been around too many of those bent motors...? :>) | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Several guys have done the Serpentine thing. There was a guy I want to think in Topeka that made a set of pulleys and was selling them but don't see the link I had to him here, might be on my laptop at home. I do have a bookmark to a thread about supercharger builds on the HAMB http://www.jalopyjournal.com/forum/showpost.php?p=3037464&postcount=36 where the guy talks about how he built his serpentine setup. See if that helps. MONGO | | |
