| | | Forums66 Topics128,181 Posts1,057,185 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83537 09/28/2007 11:19 PM | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | I took an Alternator from a 76 Chevelle and am going to mount it on the V8 small block in my 53.I am using the short water pump.The long shaft brackets that came from the Chevelle don't work.Are there any factory brackets that will fit or do I have to make one? Any info may be usefull.Thankyou Lothar | | |
#83538 09/28/2007 11:50 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Plenty of aftermarket alt brackets out there. Pick up a Goodguys catalog, Summit, Google, etc. | | |
#83539 09/29/2007 2:55 AM | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Hi Lothar.My 52 with a 350 uses a long water pump.Do you have room to use one?If so you can then use stock GM brackets Boyd | | |
#83540 09/29/2007 5:36 AM | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | You could use the bracket from a mid 60's car or truck. They mount on the front of the left exhaust manifold and have an adjustment arm that pivots on the water pump or intake manifold. Of course you have to have the correct exhaust manifold to go with it. Fred
#83541 09/29/2007 11:08 PM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Alternator brackets up through 68 on cars and 72 on trucks will work. If your heads have mount holes then the 69-72 truck bracket is simple and compact, just two bolts to the front of the head and the adjustment arm over to a water pump bolt. There getting a little hard to find.
Evan
#83542 10/01/2007 5:27 PM | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Thanks guys,I'd like to use the long shaft gear and pump, but that means I'd have to lose my chrome pulleys and buy new ones.It's the best way to go but more expensive so I'll just have to make a new alt mounting bracket.Thanks again for your input. Lothar PS.How are you making out with your 52 Boyd? | | |
#83543 10/04/2007 11:20 PM | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | If you can not find the adjustment arm, I have used a turnbuckle in many many engine installs. Makes adjusting belt tension easy, especially at the track, or on the road. Making the bracket will be fairly easy.
