2 members (DadsFirstPickup, Rusted Nut), 78 guests, and 2 robots.
Topics128,075
Posts1,056,279
Members48,441
#834598 03/12/2012 7:45 PM
I've been thinking how cool a serpentine belt would look on my 235. Hoping that some of you have did this so I'm not wasting time and money trying to figure what will work and what will not. Or is there a vendor that makes a kit? I'm using a alternator without air.
Moost serp belts run on a reverse rotation water pump, also the belt load is much higher than v- belt, might be more than the pump bearings can handle.
BC
1960 C60 pasture art
A serpentine belt needs more then one item to run around, like a/c, p/s, alt, water pump, etc....
I think maybe you are just looking at a ribbed, 4 or 6 grooved, flat back belt. If thats the case, hunt down a late model small block Chevy and see if you could rob the pulleys. You might have to adapt and modify, but it could be done. This type of belt shouldn't load the water pump any more then a V-belt does.
Joe
I genuinely doubt that you can put a serp pulley on the water pump of a 75 y/o engine. Simply not made for it and seems very difficult to modify.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
[quote=Joe H I think maybe you are just looking at a ribbed, 4 or 6 grooved, flat back belt.
Joe [/quote]
Even less load for The same grip, got me thinking now!
BC
What's wrong with the stock setup?
I'm going to have to detract my original post and side with Grigg. A stock 235 only needs a belt to run the water pump and generator. No real need for a serpentine. Unless you ad air and power steering, maybe modifying for a serpentine setup would be kind of cool. Lots and lots of fab work though.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Maybe you guy's have been around too many of those bent motors...? :>)
Dave
"MONGO"
"MONGO"
Several guys have done the Serpentine thing. There was a guy I want to think in Topeka that made a set of pulleys and was selling them but don't see the link I had to him here, might be on my laptop at home. I do have a bookmark to a thread about supercharger builds on the HAMB http://www.jalopyjournal.com/forum/showpost.php?p=3037464&postcount=36 where the guy talks about how he built his serpentine setup. See if that helps.
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
