Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (55shaker, Wayne67vert), 118 guests, and 4 robots.
Topics128,281
Posts1,058,465
Members48,490
#83518 09/28/2007 3:49 PM
Hello, I am having trouble getting my clutch to work correctly. I adjust it to the book specs. Start the truck and it won't completely disengage. I end up running the adjuster out untill the throwout is engageing the clutch constantly with a bit more pressure than I feel good about. Any suggestions? The clutch is new, resurfaced flywheel. Would there be a reason the clutch is not fullt extending? Thanks for all replies!
240,000 worker bees!
1960 Two ton Chevy
#83519 09/28/2007 4:46 PM
Have a helper depress the clutch and watch the movement(throw).Is the hydro-cyl bleeding past the seals ? Is there air still in the system? Let us know what you see happening .
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#83520 09/28/2007 5:22 PM
It isn't leaking from the slave, thats nice and dry with the dust boot off. When I depress the clutch it doesn't creep or fade like it's leaking. It's almost like the system isn't completing a full stroke.
1960 Two ton Chevy
#83521 09/28/2007 6:41 PM
Is it possible that you have the disc in backwards?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#83522 09/28/2007 7:47 PM
The disk can only be installed one way due to the shape of the disk/plate arrangement. You had me thinkin' hard for second though!
1960 Two ton Chevy
#83523 09/28/2007 8:45 PM
Sounds like air in the system to start with. Have you bled it several times?
Could also be a bad seal in the master letting fluid escape past the piston and back into the reservoir.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
#83524 09/28/2007 8:49 PM
I bled it several times. A few times with a helper pumping and holding like I traditionaly do it. I have also used my power bleeder on it. I didn't consider it leaking past the seal on maybe a poor first portion of the master cylinder stroke. Maybe I should pull that master down and look over the bores?
1960 Two ton Chevy
#83525 09/28/2007 8:56 PM
Riding in the Passing Lane
It,s best to take the cyls. off & put kits in them. They arn,t expensive. Those rubber cups in those get a lot of wear because they travel the hole cyl. every time. They generally arn,t pitted like brake cyls. get. Then bleed all the air out & it will work good. Back the adjustment rod out so there is at least a little free play in it. Running with it tight can ruin the T.O. brg. & engine crank thrust brg. Sometimes you can adjust the master cyl. rod to get a longer stroke.
1972 Chevy c10 Cheyenne Super
