1 members (Rusty Rod),
80
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 69 | I cant find them anywhere. Steele Company was less than helpful. Jim Carters has no idea. Any help would be appreciated. All it is is channel and a seal X 4. Eric | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Do you have a photo of what you are trying to replace?
Jim Carter had all the seals I needed for my 1954 Suburban side windows. All I had to adapt from Restoration Specialties, Inc. were the whiskers in the vertical stainless steel strips.
| | | | | Joined: Aug 2010 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 69 | I will take some. It is one continuous bendable whisker piece that the rear 2-piece window slides in and one rubber seal that goes between the outer frame and the stationary window. I will check that company though that u gave me.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Jim Carter carries the parts as well as Classic parts Of America. Classic Parts Of America kit Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks, Tim
That is a much more complete/convenient kit at Classic Parts than what Jim Carter lists on his website.
I wonder how well the vertical bar whiskers work on early and late vertical bars - have you tried the Classic Parts whiskers?
Also, if you ID the parts in their photo, I'll edit a copy of the photo and include the part names (and then post the photo here).
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The vertical whiskers look like they are going to be really tight,I did by a set from them.I bought some of my parts from Jim Carter and the whiskers and quarter window rubber from Classic Parts Of America. Classic Parts Of America will sell each item separate of the kit,they don't list the parts individual in the catalog but you can call or walk in and get what you need.
Tim,I'll try to ID the parts for you.
glass channels vertical whiskers wedge rubber Glass setting tape for the vertical stainless trims to glass. quarter glass rubber
I named them from the back row and then left to right and then front row.
Remember,they will sell the parts individually if you call or walk in.
Tim
| | | | | Joined: Oct 2005 Posts: 4,258 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,258 | Is it me or is that kit missing 4 pieces of setting tape and four whiskers?? Or does the setting tape get cut in half the long way? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Where do you need 8 pieces of setting tape?
Maybe:
4 x for attaching the stainless steel vertical stationary strips to the glass (on the 4 sliding windows or on the 4 stationary windows, depending on the year of your Suburban).
4 for attaching the small stainless steel clips used to move the sliding window (if your Suburban has the vertical strips on the stationary windows)
Where do you need 8 whiskers?
4 for the stainless steel vertical strips (stationary or not, depending on the year of the Suburban).
4 for ?
Post some pictures and that might help clarifying what is needed, and where it is needed?
| | | | | Joined: Oct 2005 Posts: 4,258 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,258 | Ah! Thanks Tim. That actually clears things up. Having a close look at my Burb, I have the stationary windows with no stainless. My stationaries were delaminating in such a way that I thought they had remnants a stainless trim also. So when I was collecting parts, I found some stationary glass that had trim on it.
Which years had the stationary glass with the stainless trim? Looks like I might have 2-3 pieces to sell. | | |
