4 members (Phak1, CharlieF, Peggy M, klhansen), 56 guests, and 5 robots.
Topics128,153
Posts1,056,842
Members48,456
I like the way the hub cap adapters on this page were made but making a casting is not something I do every day.
http://pic5.piczo.com/Millpower-Race-Engineering/?g=45768718
I finally came up with an inexpensive way to attach my hub caps. I started with some stock rally centers I found cheap on e-Bay. I removed the center part with a cut-off wheel and grinder. Then I drilled 3 evenly spaced holes 5/16" in from the outer edge and attached the clips with #10 machine screws, nuts and star washers. I salvaged the clips from some damaged wheels I had, but you can buy them from some of the venders for about $3 each.
http://web.etv.net/users/jmcneel/hc1.jpg
You could go with 4 or 6 clips as long as they are spaced evenly. Probably a good idea if you drive much on washboard gravel but 3 clips seem tight enough for my purposes. I then simply bolt the modified center to the rim with 5/16" cap screws.
http://web.etv.net/users/jmcneel/hc2.jpg
Then snap on the hub cap.
http://web.etv.net/users/jmcneel/hc3.jpg
Just the look I was going for.
http://web.etv.net/users/jmcneel/hc4.jpg
I've kept the chrome to a minimum for a more subtle look, only adding a few select pieces like my license plate frame!
http://web.etv.net/users/jmcneel/hc5.jpg
http://web.etv.net/users/jmcneel/59.html
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
1 Offline
That turned out sweet, GREAT JOB ! I really like the way it looks
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Now I know why I saved those ugly 4wd caps.
I had thought about modifying the 1/4 inch aluminum spacer plates that are sold with the 6 lug disc brake kits, or seperately to space the wheels out. This approach is definetely cheaper, as I already have a set of 4 4x4 center caps.
I nominate this to go in the tech tip section.
Good work there, and really great piece of recycling of the stock 6 lug rally wheel center caps too.
My rallly wheels had the 4wheel drive caps, the fronts had the hole for the locking hubs. Someone made the centers out of a can lid. I used some of the round wide view mirrors from the parts store. They are chrome reflective and come in the right size, cheep too, a little rtv and you are done.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
Thanks for the kind words. Stuart, I really would have rather been able to make a set like yours. They are almost to nice to cover up with hub caps.
Joe McNeel
