| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 54 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 54 | I'm looking at going back with stock size rims on my 58 1/2 ton along with baby moons and beauty rings. I've done some searching on here, and I think I've got the right answer, but hopefully someone can verify I'm on the right track. Best I can tell from the info I've gathered, the 15 inch wheels used in 1958 were 5 1/2" wide with a 3 1/2" backspace. Is that correct? If the weather cooperates I'm going to the junk yard this weekend to see what I can come up with that will work. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not sure on the back space, but the width was 6" by the TF years - any GM 15" 6 bolt wheels into the 70's will work and the 61 up with the hubcap 'lumps' will work best for moons rather than the earlier ones with the hubcap clips
Bill | | | | | Joined: Mar 2009 Posts: 54 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 54 | Thanks Bill. Hopefully I can find what I'm looking for this weekend. | | |
