7 members (Otto Skorzeny, dt235sd, mason86, Bill Hanlon, MickeyP, 68ironhead, Greg_H),
92
Mod | | | Forums66 Topics128,049 Posts1,055,649 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Hi guys, Ok got a new thermo. replaced all hoses, antifreeze, thermo. Now I have a leak in my heater that I didnt have before. Antifreeze leaking out under truck and onto floor in the cab. Any easy fix I hope Thanks Rick This is a new post to an older thermostat problem. wasnt sure if I should repost or continue old one
Rick 58 3600 4 on the floor
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Leaking heater core happens frequently were you running a pressure cap. After years of sitting/use the coolent slowly weakens an area. probably a pinhole. A radiator shop could evaluate if it is repairable. There are repro/nos cores available but can be $$. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 'fix' is to remove and repair the heater as necessary, might be easy or not .... until you do that you can loop the heater hoses on the engine so you're no longer routing water to the leak
Bill | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Cap looks pretty basic. Should I have pressure cap. Its a drag because I didnt have the leak before I put the new stuff on. Will I need the whole heater unit
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Cap looks pretty basic. Should I have pressure cap. Its a drag because I didnt have the leak before I put the new stuff on. Will I need the whole heater unit What size and year engine? What size truck? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | depending on the style of heater you may only need to remove a leaking Ranco valve, or you may need to repair or replace the core .... a '58 should have a pressure cap, 4-7# .... regardless if you put a 'modern' 14# cap on [bad idea], now that it's leaking it needs fixing
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Red 58 you say to loop the 2 heater hoses. Another guy told me to just block each one, which I have done already. Is that the same as looping them. Also any idea how much antifreeze this thing holds. I am wondering if i put too much in - creating to much pressure on the old heater
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the amount of antifreeze won't affect the pressure, too much just won't cool as well, consult the label and add the amount called for to get the protection you want, the system holds about 16 qts [about 15 liters] .... by looping I meant remove one hose altogether, run the other one back to the vacated fitting, same as blocking but easier
Bill | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | well red aren't you clever.That would have been much easier and cheaper. Anyway I got them blocked now so I will leave them that way till I figure out how to get the heater out of the cab. I'll save that question for another day. Thanks everyone Rick
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So, if I recall correctly, you discovered a stuck thermostat that was installed upside down and crooked. If it had been in straight, there would have been over heating and some boil over. Since it was in crooked, there was free flow and the proper operating temperature was never reached. Now that the new thermostat is in, you should have a good operating temperature and some increased pressure which probably affected the heater core. Your heater core was probably ready to fail. | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Yes truckernix I imagine you are right. I was replasing al the hoses belts just to be safe cause I didn't know how ol they were. I actually discovered that that old thermo was busted from its casing . That is why it looked weird to me. Anyway I got the 2 heater hoses plugged. Just trying to burn off (steam)all the anti I spilled on the rad
| | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | Generally a radiater shop repairs with solder I believe, but believe it or not we just fixed a heater core with J.B.Weld. Block off one end of the core submerge it water with a little air pressure, find the leaking area try to open it up a little bit sit it on a warm wood stove and inject with a plastic syrenge some good ol STRUCTURAL j.b. weld. I'll let it set fo about a day or so than submerge it back in the water bucket for about an hour at 7.5 lbs. looking for leaks if she does I go back over it again until she holds, we've done a few of them like this.Some people say this could be dagerouse because of the weld softning up and giving off fumes B.S. J.B.weld doesn't even soften up on exhaut manifolds.For $7.50 she's worth a try | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Well I had this issue as well and I had to take it around to shops getting Quotes. Think it was around $300 to recore it cause it was a honey comb or something of the sort. Anyhow, I was broke at the time and installed a universal heater and have still not got around to recoring it.
Good luck | | |
