| | | Forums66 Topics128,204 Posts1,057,292 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | So I'm gonna change the real main seal and install a new clutch kit. What's the best way to get to it? Do I have to pull out the entire rear end/ torque tube / trans? Would it be eaiset to pull the engine forward? Thanks for your help! | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | You should be able to unbolt the torque tube cover from the tranny, slide it back, undo the universal joint, slide the yoke back into the tube far enough so you can then drop the end of the torque tube down to the ground. Then you can pull the tranny.
Sometimes the yoke cannot be slid back enough because the motor/tranny has shifted on the mounts or an Oakie bushing has been installed in the torque tube. Then you may need to undo the ubolts and slide the rear end back a notch.
Good luck!
Kurt | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | thanks kurt! so am i going to need to put a oakie busing on the torque tube when i reinstall the tube to the tranny? thanks again | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | You only need to install an Oakie bushing if you are having problems with transmission oil leaking from the trans to the rear end. Otherwise, don't worry about it.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | thaNKS for your guy's help. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I just replaced my clutch on my 46 1/2 ton, I had to unbolt the front shackle bolts on my rear springs and unbolt the ujoint in the front of the tube and it will slide back about 3 inches, enough to move it out of the way,then you can get to the clutch and pressure plate from underneath | | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | I just replaced my rear main seal and only had to disconnect the U-joint (within the ball housing), slide it back enough to allow the driveline to drop down. Once down far enough to clear the back end of the tranny, pull the U-Joint, ball collar of the end of the driveline and then raised it until it touched the bottom side of the floor board.
Pulled the tranny and did my thing.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
