4 members (baldeagle, Lightholder's Dad, Hotrod Lincoln, 1 invisible), 76 guests, and 6 robots.
Topics128,018
Posts1,055,339
Members48,419
#83424 09/26/2007 1:10 AM
Apprentice
Apprentice
I have a 49 pickup with a mustang II suspension
I want to replace my full size headers with Block
hugger headers. Has anyone used these on a simular set up. Some of the sites says they can not be used on angled spark plugs but not for sure how much angle they mean. My 350 sbc is from the 70's My plugs are angle a little but not much. The one worry i have is that i might need to re-route the steering
Marcus
#83425 09/26/2007 4:23 PM
I have hugger headers with straight plug heads on my truck. The plug tops just point past the header tubes, if you have angled plugs, some of them may point straight at the header tubes which are routed very close to the head/block. It'd probably work OK, but it might be very difficult to get a wrench in to change the plugs.
Stuart.
#83426 09/27/2007 5:03 AM
Accel makes a plug called a "shorty" for use with header clearance problems. Some of the others make them also, but I don't know what they're called.
'67 GMC 3/4 292 4spd
#83427 09/27/2007 1:21 PM
49dream just check with the 18 year old salesman you talk to on the phone when you call to make the buy. He'll be able to instruct you on what header to buy. grin I bought the S & S heat-coated block huggers. Mine are for straight plugs but they also sell headers for angle plugs. They are more expensive but you know what they say, "you get what you pay for", most of the time.
http://good-times.webshots.com/photo/2534590090099708909oLnpqs
http://good-times.webshots.com/photo/2939207490099708909WjuDLm
http://good-times.webshots.com/photo/2221429590099708909UAYEzB
http://good-times.webshots.com/photo/2866629670099708909GYifND
Hope this helps.
~Jim
#83428 10/05/2007 12:43 AM
Apprentice
Apprentice
Thanks Big Chevy and others. I am afraid if I go with the block huggers I will need to re-route my steering linkage. I don't want the full size that I have now because they hang to low with my drop spindles and mustang II front end
Need to do some homework on this one
Marcus
