3 members (3B, Lonnie, klhansen), 60 guests, and 5 robots.
Topics128,186
Posts1,057,315
Members48,468
So, I'm about to put my darn 235 back together. I've even gone all out and bought some federalmogual assembly lube for the bearings. Do I want to use this stuff on the rings and cylinders, or should I just be using motor oil on the rings and cylinders? I'm using chrome faced NOS Chev rings, if that makes any difference, I dunno, I'm out of my element. I do know the packages for the rings say I don't even need to "Glaze-bust". I figure I should give 'em a little hone anyway.
Thanks everybody.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
As many years as I've built engines.....just engine oil for cylinder walls!
Mr Lang, I used chrome rings the first time I rebuilt my 235 and they slap wore out my cylinder walls in short order. At least I assumed it was the chrome rings. Have you ever heard about that happening? 2nd time I used standard rings. Maybe they were CI? Still going strong 25 years later.
I would just use motor oil for lubing the rings/pistons.
Kurt
Excellent, thank-you.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
I've never installed such fancy rings as these Kurt. Previous to today's adventure, I've only ever screwed around with Model T engines, with the 1/4" plain cast iron rings! The oil rings I put on the 235 pistons, were four pieces! Madness!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Welcome to the 21st century, Mr. Lang!
Just oil on the cyl. walls & rings, and I would hone, too.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
In my experience with a re-ring job you'll find that the cast rings will be more forgiving of a cylinder wall that is worn. They also seem to seal up better than a hard chrome ring. Either way a hone with a good scrubbing to get clean is in order. Then motor oil is best. Don
H Online: Content
Do a good crosshatch with a glaze breaker, or use a dingleberry hone if you have one. Don't believe the BS about not gleze-breaking. However- - - -and this is vitally important- - - -give the cylinder walls a thorough scrubbing with a stiff-bristle brush, scalding hot water, and detergent like Dawn or Tide, followed by lots of rinsing. I wore out a new set of rings in a Rambler flathead six on a 2,500-mile trip from California to Tennessee because of a bad cleanup after honing the cylinders during a re-ring job. By the time I got to Nashville, the engine was using 3 quarts of oil to a tank of gas, and when I tore it down, the oil ring expanders were rubbing the cylinder walls!
In addition to what Hotrod Lincoln said, which is excellent advice, I finish up the cylinders with the highest detergent oil I can get, wiping them with a white rag. Do this as many times as necessary until you get to the point the rag remains white. It is amazing the amount of crud left after scrubbing and cleaning with detergent.
