7 members (NJC, baldeagle, Gray_Ghost, Peggy M, Wickedbass, Charles in CA, cmayna),
77
7
Mod | | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83424 09/26/2007 1:10 AM | Joined: Mar 2005 Posts: 49 Apprentice | | Apprentice Joined: Mar 2005 Posts: 49 | I have a 49 pickup with a mustang II suspension I want to replace my full size headers with Block hugger headers. Has anyone used these on a simular set up. Some of the sites says they can not be used on angled spark plugs but not for sure how much angle they mean. My 350 sbc is from the 70's My plugs are angle a little but not much. The one worry i have is that i might need to re-route the steering
Marcus | | |
#83425 09/26/2007 4:23 PM | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | I have hugger headers with straight plug heads on my truck. The plug tops just point past the header tubes, if you have angled plugs, some of them may point straight at the header tubes which are routed very close to the head/block. It'd probably work OK, but it might be very difficult to get a wrench in to change the plugs.
Stuart. | | |
#83426 09/27/2007 5:03 AM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Accel makes a plug called a "shorty" for use with header clearance problems. Some of the others make them also, but I don't know what they're called.
'67 GMC 3/4 292 4spd
#83428 10/05/2007 12:43 AM | Joined: Mar 2005 Posts: 49 Apprentice | | Apprentice Joined: Mar 2005 Posts: 49 | Thanks Big Chevy and others. I am afraid if I go with the block huggers I will need to re-route my steering linkage. I don't want the full size that I have now because they hang to low with my drop spindles and mustang II front end
Need to do some homework on this one
Marcus | | |
