| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | I have a '48 chevy 2 ton with a '54 235 engine. When I first started it it ran ok and a little better upon each improvement. Now however it runs rough at about 900 to 1000 rpm. In an effort to correct this I have replaced the coil, the points and condenser, the spark plugs and wires (the cap and rotor looked ok after some scrapping the build up on the copper. I've rebuilt the carb and checked for vaccum leaks. The engine starts very easily and idles nice and smooth. Any suggestions for what might be the cause of the rough running? | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | Make sure the negative side of the coil is connected to the points. Also, if it is a 12 volt system, do you have a balast resistor between the ignition switch and the coil?
Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | di1953gmc Thanks for the response. Yes the coil is a new one that can work with an external resistor but it also has one built in and it is connected to the negative side. Ben | | | | | Joined: Oct 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 71 | Have you done a compression test and a leak down check lately? How about valve(s) adjustment? Solid lifters or hydraulic? Does it do it under load ? Have you checked your vacumn advance is working properly? How is the condition of your carb ? I know.... so many question !!!!!! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Did it start after you replace the points? If so you may not have installed the points return spring. This will cause point float when revved up. Some points come with a separate strap spring that spoons the brass connector strap.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | helilog 56, No I haven't done a compression check or adjusted valves that was my next step. I believe they're hydraulic. I can't put it under a load test not quite yet. Yes the vaccum advance is working and I have kited the carv. Actually I think it ran better before the carb kit. The puzzling part is it idles great and for the first couple r's it runs very good and smooth.
I haven't done anything more than back the truck out of my garage and drive it back in. This rough running just appeared.
Pre'68 Dave Most everything I listed in the first post was done as an effort to correct this roughness.
As I've stated before it starts very easily and runs very smooth at idle and for the first couple hundred r's. Then at about 900 and more RPM s it runs rough. Sounds like a flooded engine and I'm just waiting for it to clear up but it never does.
Thanks Gentelmen for all your help. I guess I need to pull the valve cover and check the valves. | | | | | Joined: Oct 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 71 | If excessive fuel is getting in, pull the plugs and check if they are black. You are coming off the idle circuit when opening the throttle.... what type of carb? Keep us posted ! | | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | '54 engine, I'll guess it a rochester "B' with a stuck down power piston.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Check that the spark plug order is correct. These engines can run with the plugs being out quite a few degrees. They can actually run almost well until you put the throttle to it...
Jeff | | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | It does have a rochester carb just rebuilt. Not sure where the power piston is. My carb has an accelerator pump. I'll check that. I've double checked the firing order. It's ok. The spark plugs are black sooty but not wet. Ben | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | The power piston is located next to the main metering jet. It is adjacent to the float. It is located in the top assembly of the carburetor, (part with the choke) while the accelerator pump is located in the middle assembly.
You should be able to grab the stem and move it up and down.
Kurt
| | | | | Joined: Apr 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 57 | The power piston is brass in a bore of alloy. It must be free in the bore. The idle port is below the throttle plate. You have stated that the engine runs good at idle. If the power piston is stuck on the power valve ball a rich fuel mixture is entering just off of idle. When you torque down the power piston assembly, make sure the piston is not in a bind. The manual image will put you in the right pew 'where the power piston is'. Good luck. http://chevy.oldcarmanualproject.com/Rochester/BBC03.htm
| | | | | Joined: Apr 2011 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 57 | Suggest you focus on the carb. If the spark plugs are sooty, black with carbon build up check the float level specs. This is a sign of a rich mixture. | | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | Might want to check this post too. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=834008#Post834008Power piston stuck, power ball in wrong position (goes above spring), gasket blocking off vacuum passage to power piston (credit to pre '68 Dave), will all cause a very rich mixture off idle.
