| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83339 09/24/2007 3:05 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Would it be hard to put a 283 in a 53? Has anyone done it? What else needs to be replaced to make it fit, or work? Can the bell housing, transmission and torque-tube rear end still be used?
Just asking.
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
#83340 09/24/2007 3:46 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dennis, I think any post on this site that dealt with the old 350-install would apply to the 283. They are almost the same exact beast. Stuart | | |
#83341 09/24/2007 7:51 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The older 283's had only the front engine mount holes and none on the sides as you would find on a 350. Depending on what block you have that will enter into the equasion. | | |
#83342 09/24/2007 8:48 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It,s been done many times. The biggest problem is steering gear clearance. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#83343 09/25/2007 2:56 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks, guys. It was a good idea but in my case - I think I will try to find a 235. I don't believe I have the time and/or skills to refabricate the truck for the 283.
Thanks again for all the information and advise.
#83344 09/25/2007 3:15 PM | Joined: Dec 2002 Posts: 3,437 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,437 | It's not really all that difficult to put a V8 in an old truck... use the tubular motor mounts and block hugger headers.. you can even push the engine over to the right side a bit to make more room for the steering... that will also offset all the weight sitting between the steering wheel and gas pedal.
#83345 09/25/2007 9:40 PM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I don't think I would choose a 238 for this switch. You might as well find a 350 and use it. Parts etc. are more plentiful for this engine. Good luck with which ever you choose.
~Jim
#83346 09/26/2007 1:55 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks to all for your advice and encouragement. I fit in the middle of our pack with skills and knowledge. This is a wonderful site.
Last night I noticed a 235 in the McKinney area and a 216 in Dennison. Both are described as running like sewing machines and were removed from projects for huge motors. Both are asking $300 and were on Craiglist.Dallas.
Any suggestions on looking at them or experiences with purchasing like this? Are any of these people on this site or have looked at these engines?
TIA
#83348 09/29/2007 4:53 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 283 was front mounted 'til '59 in trucks for sure, possibly later as well. Side mounts came in on cars in '58. As far as the 350 vs. 283 thing, it really boilds down to parts availability. The 350 is the cheapest engine to build, even less to build than the 283. I won't say the 283 is a bad engine, it isn't, but for overall cost of rebuilding , the 350 is the winner there.
Bill Burmeister | | |
#83349 09/30/2007 12:13 AM | Joined: Nov 2000 Posts: 119 Member | | Member Joined: Nov 2000 Posts: 119 | As far as I know, the '57 283 (first year of the 283, since '55 and '56 were all 265s) was the only 283 model to not feature the side motor mounts. I think they started the side mounts in the 1958 cars. For a long time the blocks were drilled and tapped for front mounting tabs as well. I'd say the odds of you having a '57 block are fairly low, but certainly not impossible. | | |
#83350 09/30/2007 4:40 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Most light truck V8s were still 265s in 1957 AFAIK. | | |
