5 members (Joe H, 3B, DennisM, 52hornsby, Gdads51), 108 guests, and 0 robots.
Topics128,049
Posts1,055,693
#831921 03/03/2012 11:23 PM
My 54 pickup is pretty much original except for 12 volt conversition.
Recently the speedometer quit working but the odometer works fine. What could be the problem and can it be fixed?
I'm guessing that since the odometer works that the cable is good.
Gerry
Riding in the Passing Lane
Your guess is correct. There is a problem in the speedo head. You need to get it repaied or a new or salvage one.
1972 Chevy c10 Cheyenne Super
I can buy a good used one for $75 or have mine rebuilt for $125.
My thinking is buy the good used one and do the job all at once rather then wait 2 weeks turn around time.
Any thoughts on which way is better?
The rebuilt one most likely has a better chance of being closer to accurate and a better chance of lasting a while. Assuming of course that it has had a decent rebuild. By the way where would you be sending the unit if you were to go that way? I have one I would like to get restored.
In case the OP is not aware, there is no mechanical connection between the cable driven parts of the speedo and the indicator needle. The connection is magnetic. So, unless the indicator needle post is broken, the likely culprit is dried grease preventing the magnetic pull from rotating the needle shaft. The connection is hard to explain, but sort of a magnetized cup in a larger cup. Offsetting magnets...allows for dampening out the fluctuations, etc.
The speedos are easy to disassemble and clean.
