3 members (Hotrod Lincoln, Bill Hanlon, 1955 1 Series), 77 guests, and 0 robots.
Topics128,047
Posts1,055,621
#832917 03/07/2012 3:09 AM
Wondering if there were any other changes, besides the rearend, between the 54 and 55.1 half ton? Found some 55 1st series parts and thinking I use them as spares for my 54.
open driveshaft rear end so transmission, rear leaf springs, driveshaft are different, hood side emblems and grille accent colors are the only thing I know of off hand.
The '54 had the open driveshaft didn't it? Our 3600 does, anyway. Maybe not the 3100.
Got me on that. Half tons were closed driveshaft.
My '54 had an open drive shaft, it had Hydramatic trans.
The standard from-the-factory 1954 1/2 ton truck with Hydra-Matic transmission had a torque-tube rear-end. All 1954 trucks larger than 1/2 ton had an open driveshaft.
The 1955-1st series 1/2 ton trucks (any transmission) had open drive shafts.
Professional Novice
