1 members (NJC),
138
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Wondering if there were any other changes, besides the rearend, between the 54 and 55.1 half ton? Found some 55 1st series parts and thinking I use them as spares for my 54. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | open driveshaft rear end so transmission, rear leaf springs, driveshaft are different, hood side emblems and grille accent colors are the only thing I know of off hand. | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | The '54 had the open driveshaft didn't it? Our 3600 does, anyway. Maybe not the 3100. | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Got me on that. Half tons were closed driveshaft. | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | My '54 had an open drive shaft, it had Hydramatic trans. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The standard from-the-factory 1954 1/2 ton truck with Hydra-Matic transmission had a torque-tube rear-end. All 1954 trucks larger than 1/2 ton had an open driveshaft.
The 1955-1st series 1/2 ton trucks (any transmission) had open drive shafts.
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 |
Professional Novice
