| | | Forums66 Topics128,075 Posts1,055,916 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | Have ignition switch with no key. Can a locksmith make a key? If not does anyone know how to get the key cylinder out without a key? 1953 3100 with 56 car 235 12 v. Thanks | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | yes a locksmith will be able to make a key for your ignition switch, he should also be able to rekey it if you want.
1938 Gmc 1/2 ton
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | To remove,, theres 2 screws on the bottom of the dash,,,just below the ign. switch. Take those out, label all your wires, and the switch will be in your hands. Dont forget to disconnect the battery before beginning. Marty | | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | Thanks for all the help. I just wanted to remove the key cylinder from the bracket. | | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | Took assembly to a locksmith with 2 repro GM blanks and he made me keys for $35. Thanks all. | | |
