2 members (Jon G, Lostbuthaulinass), 89 guests, and 5 robots.
Topics128,057
Posts1,055,810
Have ignition switch with no key. Can a locksmith make a key? If not does anyone know how to get the key cylinder out without a key? 1953 3100 with 56 car 235 12 v. Thanks
yes a locksmith will be able to make a key for your ignition switch, he should also be able to rekey it if you want.
1938 Gmc 1/2 ton
Sent you an e-mail.
To remove,, theres 2 screws on the bottom of the dash,,,just below the ign. switch.
Take those out, label all your wires, and the switch will be in your hands. Dont forget to disconnect the battery before beginning.
Marty
Thanks for all the help. I just wanted to remove the key cylinder from the bracket.
Took assembly to a locksmith with 2 repro GM blanks and he made me keys for $35. Thanks all.
