2 members (2-Ton, JW51), 67 guests, and 4 robots.
Topics128,055
Posts1,055,783
#832795 03/06/2012 8:16 PM
Is there an off the shelf exhaust dampener I can buy to settle down the noise from the exhaust pipe on 216 engine? I'd like to mount it on the end of the tail pipe. Would it cause any harm to do so?
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
k10 Offline
Look for a resonator with the same size pipe diameter as your exhaust system.
k10 #833013 03/07/2012 12:08 PM
what is an exhaust dampener. are you talking about engine exhaust noise or mechanical noise of the pipe rattling about?
I think he means exhaust "Resonator", as K10 posted, to mellow out the tone of the exhaust. ohwell
Exhaust Dampener is used for HVAC: http://www.comfortgurus.com/images/BD05-main3-FAM.jpg
Exhaust Resonator: http://www.automotive-online.com/gifs/diagram.jpg
Super Trapp makes these to go on the end of the tailpipe, but they are very expensive. http://www.supertrapp.com/product_sections/cat.asp?CatID=32
How about telling us what you are running for exhaust now: tailpipe size, muffler type, full length to rear bumper or ??? Adding the correct muffler should be all that is needed, and will be much more reasonable in regards to pricing. thumbs_up
OK folks, I think I've got my terminology wrong. I think I'm looking for a resonator as previously mentioned. Something I can clamp onto the exhaust tip. Lucille is a stock '46 with a 216 engine and has a 22" long 5" round muffler. The tail pipe is 1 3/4" OD. The distance from the muffler to the end of the tail pipe is 58". All I want to do is to quiet the exhaust noise down a bit. I don't want it so sound like a fart machine. Just a low rumble. Is that possible? And I don't want to spend alot of money to do it. If there is such a device what is it and where can I get one?
David Wolff
1946 Chevy 1/2-ton
Lucille #833331 03/08/2012 12:34 PM
whatever you find out let me know, I put duals with cherry bomb looking mufflers and it is mellowing out some but in the higher RPM ranges at full throttle it is positively obnoxious. (high rpm and full throttle being relative terms here)
