| | | Forums66 Topics128,068 Posts1,055,881 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Is there an off the shelf exhaust dampener I can buy to settle down the noise from the exhaust pipe on 216 engine? I'd like to mount it on the end of the tail pipe. Would it cause any harm to do so?
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Look for a resonator with the same size pipe diameter as your exhaust system. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | what is an exhaust dampener. are you talking about engine exhaust noise or mechanical noise of the pipe rattling about? | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | OK folks, I think I've got my terminology wrong. I think I'm looking for a resonator as previously mentioned. Something I can clamp onto the exhaust tip. Lucille is a stock '46 with a 216 engine and has a 22" long 5" round muffler. The tail pipe is 1 3/4" OD. The distance from the muffler to the end of the tail pipe is 58". All I want to do is to quiet the exhaust noise down a bit. I don't want it so sound like a fart machine. Just a low rumble. Is that possible? And I don't want to spend alot of money to do it. If there is such a device what is it and where can I get one?
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | whatever you find out let me know, I put duals with cherry bomb looking mufflers and it is mellowing out some but in the higher RPM ranges at full throttle it is positively obnoxious. (high rpm and full throttle being relative terms here) | | |
