2 members (Guitplayer, Lostbuthaulinass), 136 guests, and 1 robot.
Topics128,048
Posts1,055,540
Members48,425
#83276 09/22/2007 8:02 PM
[img]http://thumb19.webshots.net/t/50/550/2/84/59/2796284590101590459QxMefk_th.jpg[/img]
If you look at the shifter you can sorta see a lever that you usually see with a two speed rear end. The thing is though that it goes into the transmission and doesn't go toward the rear end. I have yet to take the transmission apart yet so I don't want it is attached indside the transmission. Any help indentifying it would be helpful.
#83277 09/22/2007 8:35 PM
Delux,
Wouldn't that be the reverse lock-out lever...pretty common on that old transmission.
Stuart
#83278 09/22/2007 9:25 PM
Riding in the Passing Lane
Shure looks like a good old original truck.
Stuart pegged it. You pull up on that lever to shift to reverse. Ther is a little spring under it that returns it but it is usually broken by now.
1972 Chevy c10 Cheyenne Super
#83279 09/23/2007 4:46 PM
So it is a four speed transmission and then you pull that lever to go in reverse.
#83280 09/23/2007 5:35 PM
You pull the lever and it allows you to shift the stick into the reverse position. Just pulling the lever does nothing by it's self.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#83281 09/23/2007 9:05 PM
Delux,
The description that accompanies the picture of this truck in the gallery states it has a three speed transmission. This means three forward speeds and one reverse, and as Grigg notes, the lever prevents the driver from inadvertently putting the tranny in reverse as he cruises into town for Goat feed and a six pack of Red Tail Ale. smile
The operator must lift the lock-out lever or the stick won't go into reverse.
Stuart
#83282 09/23/2007 10:16 PM
I thought that only the fourspeed transmissions had the lockout lever. Many people do call the truck fourspeeds "threespeeds with a granny gear," however.
#83283 09/23/2007 10:56 PM
Baldy,
Now I'm not sure! I know the gallery notes on this rig indicate it's a three speed, but don't know if they have discounted granny as being a gear.
The only info I can find for a transmission of this vintage, with the lock-out mechanism, is for a truck 4 speed! I better keep my trap shut on this one.
Stuart
#83284 09/24/2007 3:58 AM
If your talking about the gallery here on stovebolt that was me who put that in there at the time because I didn't know what that was. Also I went home this weekend and since the transmission is just laying on the floor in the shop currently i placed into different gears and all gears go forward hence it must be a four speed but likewise I couldn't get the thing to go in reverse? So now I totally confused.
#83285 09/24/2007 5:44 AM
Jed Offline
Delux,
Reverse should be found by pulling up on the reverse lock out, and shifting the transmission into what would normally have been the location of second gear.
#83286 09/24/2007 6:31 AM
4 speed crash box. 1st up high to the left. 2nd and reverse down low to the left. Reverse is actually more left. Third up high to the right, and 4th down to the right.
I got one of those setups on my 1940. I still haven't figured out how to drive the bloody thing.
