1 members (Brian Moore),
95
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83276 09/22/2007 8:02 PM | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | [img]http://thumb19.webshots.net/t/50/550/2/84/59/2796284590101590459QxMefk_th.jpg[/img] If you look at the shifter you can sorta see a lever that you usually see with a two speed rear end. The thing is though that it goes into the transmission and doesn't go toward the rear end. I have yet to take the transmission apart yet so I don't want it is attached indside the transmission. Any help indentifying it would be helpful. | | |
#83277 09/22/2007 8:35 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Delux,
Wouldn't that be the reverse lock-out lever...pretty common on that old transmission.
Stuart | | |
#83278 09/22/2007 9:25 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Shure looks like a good old original truck. Stuart pegged it. You pull up on that lever to shift to reverse. Ther is a little spring under it that returns it but it is usually broken by now. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#83279 09/23/2007 4:46 PM | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | So it is a four speed transmission and then you pull that lever to go in reverse. | | |
#83280 09/23/2007 5:35 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You pull the lever and it allows you to shift the stick into the reverse position. Just pulling the lever does nothing by it's self.
Grigg | | |
#83281 09/23/2007 9:05 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Delux, The description that accompanies the picture of this truck in the gallery states it has a three speed transmission. This means three forward speeds and one reverse, and as Grigg notes, the lever prevents the driver from inadvertently putting the tranny in reverse as he cruises into town for Goat feed and a six pack of Red Tail Ale. The operator must lift the lock-out lever or the stick won't go into reverse. Stuart | | |
#83282 09/23/2007 10:16 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I thought that only the fourspeed transmissions had the lockout lever. Many people do call the truck fourspeeds "threespeeds with a granny gear," however. | | |
#83283 09/23/2007 10:56 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Baldy,
Now I'm not sure! I know the gallery notes on this rig indicate it's a three speed, but don't know if they have discounted granny as being a gear.
The only info I can find for a transmission of this vintage, with the lock-out mechanism, is for a truck 4 speed! I better keep my trap shut on this one.
Stuart | | |
#83284 09/24/2007 3:58 AM | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | If your talking about the gallery here on stovebolt that was me who put that in there at the time because I didn't know what that was. Also I went home this weekend and since the transmission is just laying on the floor in the shop currently i placed into different gears and all gears go forward hence it must be a four speed but likewise I couldn't get the thing to go in reverse? So now I totally confused. | | |
#83285 09/24/2007 5:44 AM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Delux,
Reverse should be found by pulling up on the reverse lock out, and shifting the transmission into what would normally have been the location of second gear. | | |
#83286 09/24/2007 6:31 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 4 speed crash box. 1st up high to the left. 2nd and reverse down low to the left. Reverse is actually more left. Third up high to the right, and 4th down to the right.
I got one of those setups on my 1940. I still haven't figured out how to drive the bloody thing. | | |
