1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#83213 09/21/2007 2:38 AM
i got a 46 2 ton that has a sm420 trans in it
the one that was in it sounded like a phantom
jet engine found another in a old junk yard it sounds much better my question is were these trannys
always a little noisy? philip
#83214 09/21/2007 3:33 AM
Mine whines a bit in granny and reverse but beyond that it is relatively quiet. And it's a 1/2 ton. I also covered my floor with dynomat. I'm sure that helps. grin
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#83215 09/21/2007 3:49 AM
I don't think that a '46 would have the SM420, it didn't come out 'till mid-'47. You should have the staight cut gear 4 speed, with the reverse lock out lever on the shifter. That one will howl due to the way the gears are cut.
Bill Burmeister
#83216 09/21/2007 12:56 PM
its a sm420 someone must have swapped it out.
#83217 09/21/2007 2:09 PM
I've done the swap on my 46 1 ton. Not really too hard and the original bell housing in your year might be more compatible than later years.
My SM 420 runs quiet and smooth, no whines. There is a lot of info available on rebuilding these things and parts are not real hard to find. They are also easy to rebuild if you are so inclined.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
