7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible), 74 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#832117 03/04/2012 5:25 PM
I have a 46 1/2 ton with the 216. There is a Z bracket that attaches to the left splash pan that I believe is used to connect the break pedal return spring. Every way I can figure to attach it, the clutch linkage hits it. Can any one explain or provide a picture of how the break return spring is to be installed?
Also was there a spring between the floor board and the gas pedal. Mine came with one but I am not sure it should be there. If not with the new felt in the floor board the carb return spring does not fully pull back the carb linkage.
Thanks You.
I don't know if this will help but I found this
http://chevy.oldcarmanualproject.com/shop/1942_47/4247csm657.htm
Explore that website for tons of reference info.
Good luck.
Professional Novice
Thank You. Still not quite what I need to figure this one out.
