1 members (1 invisible),
70
Mod | | | Forums66 Topics128,179 Posts1,057,160 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Does anyone know where to buy the rubber seal washers that are mounted where the Trico motor penetrates the cab on a 46 just above the windshield? I'm thinking that maybe I should just modify a washer that I can find in a hardware store. I don't see these washers/seals in the Steele catalog. Suggestions anyone?
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Mine came with new wiper motor I bought from Jim Carter. They are a double shouldered rubber washer ( groove in center where sheetmetal sits ) Kinda like a grommet washer. | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Britcon, can you post pics please?
| | | | | Joined: Aug 2010 Posts: 127 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 127 | I got mine at Jim Carters, its only a couple bucks, it does have a "keyway" type slot in it, so it fits just right. | | |
