Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
1 members (Danielbolt), 487 guests, and 1 robot.
Topics126,777
Posts1,039,267
Members48,100
Most Online2,175
Jul 21st, 2025
Does anyone know where to buy the rubber seal washers that are mounted where the Trico motor penetrates the cab on a 46 just above the windshield? I'm thinking that maybe I should just modify a washer that I can find in a hardware store. I don't see these washers/seals in the Steele catalog. Suggestions anyone?
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
Mine came with new wiper motor I bought from Jim Carter. They are a double shouldered rubber washer ( groove in center where sheetmetal sits ) Kinda like a grommet washer.
1940 Chevy KC 1/2-Ton
Britcon, can you post pics please?
1946 Chevrolet 1/2-ton
More pix on Photobucket
all you need is a flat piece of gasketing material to go between the cab and the bezel, called wiper shaft gasket - also at Jim Carters
I got mine at Jim Carters, its only a couple bucks, it does have a "keyway" type slot in it, so it fits just right.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.699s Queries: 14 (0.027s) Memory: 0.6120 MB (Peak: 0.6581 MB) Data Comp: Zlib Server Time: 2025-09-22 04:58:04 UTC
Valid HTML 5 and Valid CSS
