Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (78buckshot), 43 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#831321 03/01/2012 7:57 PM
Will boring out the engine (235) to .060 weaken the engine or cause it to run hot.
3B Offline
Hy larryelvick, according to the parts book GM only offered pistons as large as .040" oversize. That being said in my experience .060" is the usual large size limit to reboring most engines. The newer engines with their thin wall castings cannot be bored even to .060" I have safely bored 265 V8 and 283 V8 blocks to .125", the last 261 rebuild I did for a customer was a 1955 - 62 block which was succesfully bored to .080" with no operating problems whatsoever. There is a new tool in the machine shops arsenal, sonic testing to check the thickness of the cylinder walls, hope that helps.
3B #831357 03/01/2012 10:10 PM
A good many 235's were reported to have been bored .125 but I cannot confirm it. That being said I wouldn't hesitate to bore one .060 to .080. I did bore mine .060 in fact and it runs cool as a cucumber.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Thanks for the info guys.
Larry
8
8 Offline
Everything I've read over the years states that a 235 block can handle boring to .090 with absolutely no problem. Above that, I don't know...
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
I bored my 54 Chevy 235 block .060 and no problems. Still running after 11 years. Good luck.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
hankrags #831605 03/02/2012 7:18 PM
Same here, '60 235 bored .060" many years & many miles ago, no issues.
BC
1960 C60 pasture art
BC59 #831616 03/02/2012 8:10 PM
59 261 bored .060, been running almost 10 years. It runs 180 al day long, in traffic may get to 190, has never overheated.
Tommy
59 apache 1/2t
261 short stepside
Tommy #831664 03/02/2012 11:55 PM
1953 Powerglide 235 bored .60 over 26 years ago. No problems.
kurt
The "sonic test" device from 60 years ago was an 8-ounce ball peen hammer. A good machinist could find thin spots and sand pockets by tapping inside a cylinder and listening for different sounds of the hammer strike. I've seen my father offset-bore a flathead Ford engine to move the center cylinders away from each other to avoid the built-in thin spot around the exhaust ports, and go .250" oversize on some of the race engines he built. He had to grind the small end of the connecting rods to let the pistons center up in the cylinders on the four middle ones. Of course, these were very short life engines, particularly when they ran on alcohol and hydrogen peroxide at 11:1 compression.
