4 members (BC59, Gdads51, carbking, papas52), 89 guests, and 3 robots.
Topics128,181
Posts1,057,180
Members48,465
Does anyone know where to buy the rubber seal washers that are mounted where the Trico motor penetrates the cab on a 46 just above the windshield? I'm thinking that maybe I should just modify a washer that I can find in a hardware store. I don't see these washers/seals in the Steele catalog. Suggestions anyone?
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
Mine came with new wiper motor I bought from Jim Carter. They are a double shouldered rubber washer ( groove in center where sheetmetal sits ) Kinda like a grommet washer.
1940 Chevy KC 1/2-Ton
Britcon, can you post pics please?
1946 Chevrolet 1/2-ton
More pix on Photobucket
all you need is a flat piece of gasketing material to go between the cab and the bezel, called wiper shaft gasket - also at Jim Carters
I got mine at Jim Carters, its only a couple bucks, it does have a "keyway" type slot in it, so it fits just right.
