| | | Forums66 Topics128,158 Posts1,057,023 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83148 09/19/2007 9:01 PM | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | Help! Could anyone measure the length (shortest point of notch to notch in bar) of the spreader bar for a 1955 to I think 1960 1/2 ton pickup Emergency Spreader bar or Strut bar and post it here. Just trying to make sure I have the correct ones before I go buy new brake shoes. Thanks I will also try to post a picture tomorrow of the one I have! | | |
#83149 09/19/2007 9:34 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | here ya go Barry, the rear shoes are Raybestos 55-RR Bill | | |
#83150 09/20/2007 2:39 PM | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | | | |
#83151 09/20/2007 2:43 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you gottem, and the right shoes .... except if that last pic is the left rear [judging by the muffler], you've got the shoes backwards, the short [primary] shoe goes to the front, all corners
Bill | | |
#83152 09/20/2007 3:01 PM | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | Thanks Red58 The Problem is when I install them it holds the shoe to the left about a 1/2 inch off the pivot cam at the top | | |
#83153 09/20/2007 3:13 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might be you just need to bash things a bit to get everything seated right - if the numbers are correct [55RR and length] might be cuz the shoes are backwards, try switching the shoes, tho' I think the 'core' part is identical for primary and secondary - those things are a pain .... make sure that spring on the end is seated and the "ear" on the spring isn't hanging it up
Bill | | |
#83154 09/20/2007 3:53 PM | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | Bill when I took them off like that I kind of thought the shoes where reversed but thats the way I took them off and they had worked like that before so I did not question it to much till I was tring to get the e Brake to work.I will compare measurements with yours and fix the brake oreintation problem and try again. Thanks again! | | |
#83155 09/20/2007 9:01 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If the shoes wont go back far enough to contact the anchor the emergency cables are stuck or adjusted up to tight. Also a stuck wheel cyl. will cause this but I,m shure you serviced them before putting on new shoes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
